Creating ConnectCAD reports
  The report commands in the ConnectCAD > Documentation menu create a variety of worksheets for labeling and reporting purposes.
The available commands come from the content in [Vectorworks]\Libraries\Defaults\Reports_Schedules\ConnectCAD\ConnectCAD Reports.vwx. To add report commands to the menu, copy the ConnectCAD Reports.vwx file to the corresponding user folder location and edit it; the changes apply when Vectorworks is restarted. Preformatted worksheet reports are also available in the Create Report dialog box (see Using preformatted reports).
Device reports list jackfield and terminal panels individually, with the number of holes used. This is helpful when trying to optimize patch-panel and term-panel layouts.
             Command  |
             Description  |
             All Layers Circuit Report  |
             Creates a worksheet listing all circuit parameters from all layers  |
             Cable Pull Report  |
             Creates a worksheet listing the number and type of cables to be installed for each cable route. This information is especially useful for bulk cable installations.  |
             ConnectCAD Parts Report  |
             Creates a worksheet listing all the devices, equipment, adapters, racks, and rack frames. Unique device names and equipment names display only once.  |
             Current Layer Circuit Report  |
             Creates a worksheet listing all circuit parameters from the current layer  |
             Current Layer Device Report  |
             Creates a worksheet listing devices and summarizing devices and parameters from the current layer  |
             Device Connections Report  |
             Creates a worksheet listing the circuits connected to each socket on each device; this provides a quick way to find which cables connect to a given device  |
Additional helpful worksheets are in [Vectorworks]\Libraries\ConnectCAD\Worksheet Samples. For example, SyncedDeviceEquipData.vwx lists devices and equipment items and summarizes items by device name. This is useful for editing the common attached records of the devices/equipment in a single step.
Once a worksheet has been created, two-way worksheet editing is useful for updating the drawing from the worksheet; see Editing drawing objects from a worksheet.
For information about creating a worksheet listing the equipment installed on a 2D equipment rack, see Creating a 2D rack contents worksheet.
Finding objects in a report
           Command  |
           Path  |
           Find in Report  |
           Context menu  |
This command locates drawing objects in a worksheet report. The worksheet needs to be open for the item to be found.
To find an object in a report:
Right-click on an object in the drawing and select the command.
In the worksheet, the object's row is selected.
Two-way worksheet editing is useful for updating the drawing from the worksheet; see Editing drawing objects from a worksheet.
