Repeating commands
Repeating the last command
Command
Path
Shortcut
Repeat [last command]
Edit
Context menu
R
The Repeat [last command] command enables you to use the most recent command. After you use a menu command, Repeat is followed by the command name (for example, Repeat Rotate).
If no commands have been used in the session, this command is named Repeat Last Command and is grayed.
To repeat the last command:
Select the command.
If executing the command typically opens a dialog box, repeating it opens the dialog box with the most recent settings. If there is no associated dialog box, the command is executed immediately.
The shortcut key to repeat the last command can be customized; see Modifying special shortcuts.
Repeating recent commands
Command
Path
Recent Commands
Edit
Context menu
The Recent Commands command displays a maximum of the ten most recently used commands.
To repeat a recent command:
Select the command.
The command history opens.
Select a command from the command history. The most recently used command is displayed at the top. Commands that cannot be executed with the current selection are grayed.
Clearing the last command and the command history
The following actions clear the last command and the command history:
Closing Vectorworks
Changing workspaces
Clicking Reset in the Vectorworks Preferences dialog box
The following actions do not clear the last command or the command history:
Creating, opening, or closing a file
Switching to a different file
Excluded commands and menus
The following commands cannot be repeated.
Menu
Excluded commands
File
New
All Open commands
All Close commands
All Save commands
All Revert commands
Quit
Edit
Undo
Redo
Cut
Copy
Paste
Paste In Place
Text
Font
Size
Font Style
Alignment
Spacing
Capitalization
Window
All menu commands
Help
All menu commands
Commands on the following menus cannot be repeated:
Quick Preferences menu
Some context menus (for example, a list browser menu)
Utility menus
