Modifying special shortcuts
You can modify the keyboard shortcuts for switching between modes on the Tool bar, for activating snapping functionality, and other special features.
To modify special shortcuts:
Access the Workspace Editor dialog box as described in Personalización de los espacios de trabajo.
Click the Keys tab to display the keyboard shortcuts for the workspace currently in use, and modify the assigned shortcut keys.
Parameter
Description
Mode Groups
Sets the shortcut keys to switch modes for the active tool; the key in 1 controls the first mode group, the key in 2 controls the second mode group, and so on
Other Keys
Sets the keyboard shortcuts for the functions below
Toggle SmartCursor Cues
Press this key to toggle on and off the SmartCursor cue display
Toggle Angles Relative To Prior Segment
Press this key to toggle whether angle snaps are set relative to the axes or to the previously drawn segment
Set Datum
Press this key to create a datum point for snapping at the current cursor location
Snap Loupe
Press this key to open the Snap Loupe window
Set Smart Point, Edge, or Vector Snap Lock
Press this key to set a smart point, smart edge, or vector snap lock at the current location
Toggle Automatic Working Plane
Press this key to toggle on and off the automatic working plane functionality; see Uso de los planos de trabajo
Suspend Snapping
Press and hold this key to disable snapping temporarily
X-ray Select Mode
Press and hold this key to see and select objects that are normally obscured behind 2D object fills or 3D rendered objects; see X-ray Select mode
Coincident Selection
If the cursor is over multiple objects at the current location, press and hold this key and click to open a dialog box from which you can select one or more of the objects; see Selección de objetos coincidentes
Close Polygon, Polyline, Wall Network or Path Objects
After completing all but the final click, press the keyboard shortcut to automatically close polygon, polyline, polygonal wall network, or path-based objects
Toggle Multiple View Panes
Press this key to toggle on and off the display of multiple view panes
Trigger Smart Options Display
If desired, assign a shortcut to toggle on and off Smart Options Display in the drawing area; Use Smart Options Display must be selected on the Smart Options Display pane of the Vectorworks Preferences dialog box
Launch Quick Search
Press this key to open the quick search window
Repeat Last Command
Press this key to use the most recent command
Snapping Keys
If desired, assign keyboard shortcuts to toggle each snapping tool
Ventana de aplicación
Indicaciones del cursor SmartCursor
Acoplamiento a ángulos
Acoplamiento a puntos inteligentes
Acoplamiento a bordes inteligentes
Creación de bloqueos de vector
Cómo usar la lupa de acoplamiento
