Parametric constraint errors
Occasionally, an editing operation cannot be performed due to conflicting or unsolvable constraints placed on the objects involved. When this occurs, an alert dialog box opens to preview the unsolvable constraints and remove them if needed.
To solve conflicting constraint errors:
When an unsolvable constraint occurs, an alert dialog box opens. Decide how to resolve the conflicting situation.
Parameter
Description
No
Continues with the editing operation, removing the conflicting constraints
Yes
Cancels the editing operation, preserving constraints
Preview
Opens the Unsolvable Constraints dialog box, listing the problem constraints so that you can preview each one
Select Preview constraints that will be selected, and then click Yes to preview the unsolvable constraints.
The Unsolvable Constraints dialog box opens.
Double-click an unsolvable constraint to preview it in the drawing. The unsolvable constraint displays with a different color.
Click OK to remove the constraints and perform the editing operation, or click Cancel to retain the constraints and cancel the editing operation.
Edición de restricciones paramétricas
Eliminación de restricciones paramétricas
Cómo cambiar el valor de una restricción dimensional
