 Modifying trusses and systems
  The truss context menu provides options for selecting and editing truss objects or entire systems. Right-click on a truss object in the drawing, and select the desired command from the context menu. Many of these commands are also available on the Object Info palette.
| Command | Description |
| Customize Truss Symbol Data | Opens the Truss Properties dialog box for Modifying truss symbol data |
| Select Objects of Same Symbol | Selects truss objects with the same Symbol definition |
| Select Objects of Same Cross Section | Selects truss objects with the same Cross section parameter |
| Select System Objects | Selects all truss objects connected within the same system, along with all associated loads, hoists, and so on |
| Change Trim Height of System | Opens the Change Trim Height dialog box for Cómo cambiar la distancia vertical de un sistema |
| Change Configuration | Opens the Change Replace Truss Configuration dialog box for Replacing truss configurations |
| Rename Truss System | Opens the Change Truss System Name dialog box for Renaming truss systems |
| Convert to Hanging Position | Selects the entire system, including the truss and any connected rigging objects, for conversion to one or more hanging positions. Any attached loads are associated with the created hanging position(s); see Creación de objetos de posición de suspensión . |
Custom shortcuts can be assigned to the commands; see Modifying menus and commands.
