Placing a Camera Match mask
Tool
Tool set
Camera Match Mask
Visualization
Masking can hide parts of a rendered model that should be behind objects in the photo image. While complex masking (for example, hiding many tree branches) may be best left to an image editing application, much can be done directly in the Vectorworks program using Camera Match masks. Masks also allow clones to be created, scaled, and rotated, for better blending.
While a mask object can be placed over the model in one step, it can be difficult to see the parts of the photo where you want the mask. However, you can first create a temporary mask object, allowing the desired parts of the photo to be seen.
Mode
Description
Polyline creation options
Specifies the method for drawing the polyline shape for the mask
Fillet Radius
Sets the fillet radius when the Arc Vertex mode is selected
Preferences
Opens the object properties dialog box to set the default preferences for camera match masks
To create a Camera Match mask:
Render the Camera Match view and crop the viewport if needed.
While in the viewport Edit Annotation mode, click the tool, and roughly draw a polyline object over the area of the model to be masked.
Once drawn, the mask object brings the parts of the photo that it contains to the front of the model. Now the parts of the photo that need to be worked on can be seen. This mask is temporary and is deleted after the final mask is placed.
Using the Camera Match Mask tool, draw another polyline only over the parts of the photo that need to be in front of the model.
After drawing the polyline, the final Camera Match mask object is created. Delete the temporary mask and examine the results. If needed, double-click on the mask to enter Edit Point mode. While in this mode, individual points can be moved, added, or deleted.
The settings of a selected Camera Match mask can be edited from the Object Info palette.
Parameter
Description
Anti-aliasing
This option helps blend the edges of the mask with the rendered model. Select a value from 0–9.
Line Mode
Gives a mask object no fill and masks only along a path of the specified Line Width. This is useful for masking thin, linear type elements such as electrical wires and tree branches.
Convert Path to Outline
(Line Mode mask required)
Converts a selected line mode mask object into a regular mask (Line Mode deselected), while giving it a path that matches the outline shape of the line mode mask. This makes it easy to draw linear-shaped masks that need to be edited to add variations to their thickness.
Once converted, the mask cannot be converted back to Line Mode.
Clone Mode
Allows a mask object to shift the photo image it displays. The mask object acts similar to the Clone tool in image editing applications.
Clone Scale
Scales the cloned image within the mask object. This allows cloned areas that are of a different size to be scaled to better blend with the area where they are placed. A good example of this would be cloning part of a brick wall that is farther from the camera view than the area where it is being placed. Clone Scale scales the bricks for a better match.
Clone Rotation
Rotates the cloned image within the mask object. This allows cloned areas that are of a different angle to be rotated to better blend with the area where they are placed. A good example of this would be cloning part of a brick wall where the angle of coursing may not quite align with the brick in the area where it is being placed. Clone Rotation rotates the image for a better match.
Cloning an area with a Camera Match mask
Tool
Tool set
Camera Match Mask
Visualization
To clone an area with a Camera Match mask:
As previously described, use the tool to place a mask over the desired area for the cloned image.
Select the mask object. Select Clone Mode from the Object Info palette.
A handle is placed on the mask object.
When the mask object is selected, a dashed outline highlight also appears at the grip location. This indicates the area of the photo used for the clone.
Move the handle to an area in the image to clone; that part of the photo appears within the mask object.
Example of cloning, scaling, and rotation with the Camera Match mask object
Example of Line Mode with the Camera Match mask object
Placing a Camera Match shadow
Camera Match
