Managing door hardware sets
Tool |
Tool set |
Shortcut |
Door
Building Shell |
Alt+Shift+D (Windows) Option+Shift+D (Mac) |
The Hardware pane of the Door Settings dialog box allows you to select items from the door hardware library to attach to door objects. The library includes information about each hardware set, which appears in the door hardware legend (see Confección de inventarios de puerta). The library also includes a symbol to represent the hardware in 3D views of the door.
Use the Manage Hardware option in the Door Settings to customize the default content hardware library as needed, for yourself or for a workgroup.
To manage door hardware sets:
Click the tool and then click Preferences.
Alternatively, select an existing door object, and click Settings in the Object Info palette.
The Door Settings dialog box opens.
On the Hardware pane, select Include hardware.
Click Manage Hardware.
The Door Hardware Library dialog box opens.
Parameter |
Description |
Door hardware list |
Lists descriptions of all defined hardware sets |
Add |
Creates a new hardware set |
Remove |
Removes the selected hardware set from the library. When prompted, confirm the deletion. Existing instances of the hardware set in the drawing are not modified. |
Edit |
Edits the selected hardware set |
Click Add, or select a set and click Edit to open the Add or Edit Door Hardware Set dialog box.
A Description and Hdw Set ID are required for each set; other parameters are optional.
Parameter |
Description |
Description |
Enter a description of the hardware set |
Hdw Set ID |
Enter a unique ID for the set |
Hinge Qty |
Enter the number of hinges |
Hinge Type |
Enter the hinge type |
Lockset Type |
Enter the lockset type |
Closer Type |
Enter the closer type |
Stop Type |
Enter the stop type |
Key Code |
Enter the key code |
Notes |
Enter notes about the door operator device |
Symbol |
Select a symbol from the default content to use in 3D views of the door |
The edited library file is saved to your user folder. To use the library in a workgroup environment, move the file to a shared workgroup location; the folder structure must be the same as that of the default content library.
[User]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
[Workgroup]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
