Land03451.pngEditing the hydrozone method list
The hydrozone’s Method list contains default options for selection; this list can be customized. Customized lists are saved in the user folder.
The Method can be selected for display in the tag/label object.
To customize the hydrozone method list:
From the Method list in the Object Info palette of a selected hydrozone, select Edit Method List.
The Edit Irrigation Method List dialog box opens.
Parameter
Description
Items are displayed in list order; click and drag within the # column to change the order
Irrigation Method
Lists the items that display in the hydrozone Method list
Add
Adds a new item to the list
Edit
Renames the currently selected list item
Delete
Deletes the currently selected list item
Customize the list by adding, renaming, or deleting items. Additional possible hydrozone methods include micro-sprays, root watering systems, soaker hoses, sub-surface drip systems, and so on.
Creación de hidrozonas
Adición de rótulos a objetos de riego
