 Replacing lighting devices
  | Command | Path | Shortcut |
| Replace Lighting Devices | Spotlight | Ctrl+Shift+Alt+R (Windows) Cmd+Shift+Option+R (Mac) |
Replacing a single lighting device
To replace an individual lighting device with another type of device:
Select the existing device.
From the Object Info palette, click Replace Lighting Device.
From the Resource Selector, double-click the replacement device.
Replacing selected lighting devices
To replace selected lighting devices with another type of lighting device:
Select the lighting devices to be replaced.
Select the command.
The Replace Lighting Devices dialog box opens.
Click Replace selected lighting devices.
Click the Resource Selector, and double-click a resource to select it.
Replacing all lighting devices of one type
To replace all lighting devices of one type:
Select the command.
Click Replace All.
