Inserting a soffit
The soffit accessory has a “pork chop” profile.
To add a soffit accessory to a roof:
From the Create Roof Accessories dialog box, select Insert Soffit, and click Soffit Settings. The Edit Soffit Settings dialog box opens to set the parameters.
Parameter |
Description |
Recess |
Specifies the distance between the bottom edges of the roof rafters and the soffit |
Trim Depth |
Specifies the distance between the outer edges of the rafters and inside edge of the soffit |
