Arch02678.pngInserting an attic
To add an attic accessory to a roof:
From the Create Roof Accessories dialog box, select Insert Attic, and click Attic Settings. The Edit Attic Settings dialog box opens to set the parameters.
Parameter
Description
Full Height
Specifies that the attic space is the full height of the attic area
Partial Height
Specifies that the attic space is the height entered in the box provided
Cómo agregar accesorios a una cubierta
