Roof face properties
The roof face parameters can be edited from the Object Info palette. The roof face parameters are described in Creación de planos de cubierta and Roof preferences. Only the parameters that are different are described here.
Parameter |
Description |
Remove Mitered Edges |
If the roof face was connected to another roof face with the Connect/Combine tool using Miter Roof Face Joins mode, click to reset the eave to the original Eave Cut (if needed), and reset all other edges to vertical cut geometry |
Dormer Settings |
When the roof face includes one or more dormers, their parameters can be set. Parameter settings affect all dormers in the roof face. |
Wall Thickness |
Sets the thickness of the walls in the dormer |
Roof Thickness |
Sets the thickness of the dormer roof |
Style |
Displays the current roof style. You can convert the roof to unstyled or see Replacing roof styles from the Object Info palette or Edición de estilos de cubierta |
Wall Clipping |
Indicates whether the roof face is associated with a set of walls, and provides the ability to associate the roof with a set of walls, or disassociate walls from the roof |
Components |
For unstyled roof faces, opens the Roof Components dialog box to define or edit roof components; see Creación de componentes de cubierta |
