Reshaping objects with the Freehand tool
| Mode | Tool | Tool set | Shortcut |
| Freehand Edit
 | Freehand
 | Basic | Alt+5 (Windows) Option+5 (Mac) |
A polyline, polygon, rectangle, circle, or arc can be reshaped using the Freehand Edit mode of the Freehand tool. The direction of the curve drawn determines the new object shape. An edited object is converted to a polyline after editing is complete.
To reshape objects using the Freehand tool:
Select a valid object.
Click the tool and mode.
Click to draw the new curve, editing the valid object using the following curve direction guidelines:
| Action | Guidelines |
| Change existing curve |
| Connect two points with new curve |
| Create closure with new curve |
| Add a new curve to an existing curve |
| Extend existing curve |
| Retain partial curve |
Click again to finish drawing the freehand polyline edit. The valid object is edited and converted to a polyline.
