Splitting or trimming 3D objects
Tool
Tool set
Project
3D Modeling
The Project tool projects a 2D object or NURBS curve onto a NURBS surface, solid, or subdivision object, and then splits or trims the solid object according to the region selected. This allows nonlinear splitting or trimming of objects to create different shapes or cut a hole in an object.
Mode
Description
Split
Splits a solid object with a projection
Trim
Trims a solid object with a projection
Add
Adds a projection to a NURBS surface
Add Upward
(Add mode only)
In Add mode, adds the projection in the profile plane normal direction
Add Downward
(Add mode only)
In Add mode, adds the projection in the opposite direction from the profile plane normal direction
Add Both Directions
(Add mode only)
In Add mode, adds the projection in both the profile plane normal direction and the opposite direction
Project and split
Project and trim
Project and add
Creación de nervaduras
Splitting objects and NURBS surfaces with the Split tool
Concepto: curvas y superficies NURBS
