ArchLand03127.pngHardscape properties
Many of the parameters on the Object Info palette are identical to those used to create the hardscape object (see Diseño de objetos de pavimento ). Only the parameters that are different are described here.
Parameter
Description
Shape Tab
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Cómo cambiar estilos de objeto de complemento en la paleta Información del objeto.
Editing a style changes all instances in the file that use the style.
Hide style parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Hardscape Settings
Click to edit the selected hardscape object. Only one hardscape can be selected at a time when editing its settings.
To modify the default hardscape object settings, click Preferences on the Tool bar.
General
Hardscape Name
Provide a name for the hardscape, for use in tags and reports
Path Width
Enter the width of the pathway hardscape object
Path Offset
Sets the offset of the pathway centerline from the placement line
Joint I/J Scale
Specifies the size of the joint pattern units, for flagstone, pavers-grid, and pavers-running joint patterns
Joint Pattern Angle
Specifies the rotation angle of the joint pattern
Border Pattern Size
Sets the width of the spaced joints, when spaced joints are selected for the border
Border Pattern Angle
Enter the angle of the pattern inside the border
Draw 3D
3D Type
Changes the 3D hardscape type; see Diseño de objetos de pavimento .
A slab with a pathway configuration cannot be changed to a slab drainage type.
Elevation
Sets the elevation of the hardscape
Main Area Components/ Border Components
For an unstyled main area slab, opens the Hardscape Main Area Components or Hardscape Border Components dialog box to specify the hardscape components; see Creación de pavimentos
Border Components
For an unstyled border slab, opens the Slab Components dialog box to specify the components; see Creación de componentes de losa
Site Modifier
Site Modifier
Changes whether the slab modifies the site model; see Creación de pavimentos
Enable aligned surface
Defines the hardscape object with a user-defined polyline similar to the boundary type; the hardscape aligns vertically along the edges of surrounding geometry
Slope Definition
(Slab type with Enable aligned surface deselected)
Select the method of defining the slope, or select None for a flat pad. After selecting the method, specify the Slope, the Elevation at End of the slope, or the Contour Angle, and the other values are automatically calculated and displayed.
Show Slope
(slab or slab modifier only)
Displays a modifiable slope arrow and the current slope in Top/Plan view; Show Slope only displays if the slope is a value other than zero. The slope displays interactively by moving one of the control points.
Show Slope A
Displays the slope A arrow and slope parameter. The slope displays interactively by moving one of the control points.
Show Slope B
Displays the slope B arrow and slope parameter. The slope displays interactively by moving one of the control points.
Constrain Slope A/B Downward
Forces the A and/or B slope to fall towards a lower elevation
Realign
(Aligned surface slab)
Resets the surface alignment with surrounding geometry
Hardscape Profiles
Modifies the surface of the hardscape with profile lines; see Modifying aligned hardscapes with profile lines
Profile
Scrolls through the profiles, highlighting the selected one; click the center button to highlight the current profile
Name
Displays the name of the currently selected profile
Profile Line Class
Select <Hardscape Class> to place the profile in the same class as the hardscape; select a class, or create a new class, to control profile line appearance and visibility.
Show Profile Lines
Toggles the display of all profile line parameters (name, slope, elevation, and markers)
Show Profile Names
Toggles the display of all profile names
Show Slopes
Toggles the display of all slope values
Show Vertex Elevation
Toggles the display of all vertex elevations
Show Profile Line Markers
Toggles the display of all profile markers
Add Profile
Adds a profile line to the hardscape for modifying the surface
Edit Profile
Enters editing mode for the selected profile, for Modifying aligned hardscapes with profile lines
Reverse Direction
Reverses the direction of the profile line section
Profile Line Marker Style(s)
Opens the Set Marker Style dialog box, to select the profile marker type at each end of the profile line; markers can be the same (Match Beginning) or different (Differentiate) at each end of the section line
Delete Profile
Deletes the selected profile
Surface Modifiers
(Aligned surface slab only)
Modifies the surface of the hardscape with stake and grade objects
Show Stake Objects
After modifying the hardscape with stake objects, displays the stake objects
Show Grade Objects
After modifying the hardscape with grade objects, displays the grade objects
Edit Surface Modifiers
Click for Modifying aligned hardscapes with surface modifiers
Information
Main Area
Displays the size of the main area
Border Area
Displays the size of the border area
Footprint Area
Displays the area of the entire footprint of the hardscape
Main Perimeter
Displays the perimeter measurement of the main area polyline
Border Perimeter
Displays the perimeter of the border only
Footprint Perimeter
Displays the perimeter measurement of the entire footprint polyline
Update Calculations
Updates the area and volume calculations displayed in the Object Info palette for the area of the site model located under the site modifier (grade limits must exist around the pad)
Site model area and volume data
Displays the area and volume information for the site model area located under the site modifier; select the units for the area and volume (grade limits must exist around the pad). For more information, see Site model properties.
Vertex parameters
Edits the vertices of the path object that the hardscape is based upon; see Editing vertex-based objects
Render Tab
Texture
You can apply and manage textures for Slab and Slab Drainage type hardscapes on the Object Info palette Render tab. See Managing object textures from the Object Info palette and Textures on objects with components.
To set individual border segments to invisible for boundary hardscapes or cut-out holes, select the hardscape object, and then click the Reshape tool. Click Hide or Show Edges mode. Click the midpoint of the hardscape border segments or the cut-out hole to hide. Repeat this process to set the border segments back to visible, if necessary.
To quickly determine the left and right side of a pathway hardscape object, select the hardscape object and click the middle button next to the Vertex field on the Shape tab of the Object Info palette; when the button is clicked, the first vertex of the hardscape object is highlighted with a red box.
When classing the subcomponents of the hardscape object, such as for the joints or tags, the class visibility of the specified class controls the visibility of the corresponding subcomponent. The class attributes are only applied to the corresponding subcomponent when the Use at Creation option is selected for the class. For example, if the Joint Class is set to the Hardscape - Component - Main Joint class, and that class specifies a hatch Fill Style, edit the class and select the Use at Creation option to apply the fill attribute. See Setting class attributes.
A hardscape object can be used as the basis of a retaining wall. This provides the ability to sculpt the site model around the hardscape. See Creación de muros de sostenimiento.
Edición de los objetos de pavimento
Reshaping a hardscape object
Conversión de objetos de pavimento en otra configuración
Alineación de pavimentos con la geometría actual
Workflow: Creating a section view of a hardscape
Editing sloped hardscapes
Hardscape tag appearance
Specifying hardscape joint patterns
Edición de rellenos y tramas con junta de pavimento
