ArchSpot02770.pngStructural member settings
Structural member properties can be set in the Structural Member Settings dialog box before the structural member object is inserted in the drawing; access it by clicking the Structural Member tool and then clicking the Preferences button from the Tool bar. These preferences serve as the new default for structural members inserted in the drawing until the preferences are changed.
To set the structural member settings:
Click the Profile tab and set the parameters. The Member graphic reflects the Member Type but not the shape.
Parameter
Description
Member ID
Enter the member ID
Structural Usage
Select the structural usage for informational purposes; select Other to enter a custom usage
Member Type
Select whether to create a steel, concrete, wood, or custom member
Select Shape
Opens the Select [Material] Shape dialog box. Click the Shape selector and double-click a structural shape to apply it. The available shapes depend upon the selected Member Type.
Specify the shape’s dimensions; the options vary depending on the Member Type selected.
If Custom Member Type is selected, you can select a custom 2D shape (one that you have created and saved as a symbol definition, in a file in the user folder).
To use a material resource, select Use Material, and select a material from the Resource Selector.
Material/Shape/Series/Size/Major and Minor Depth and Breadth
These static text fields display the settings from the Select [Material] Shape dialog boxes
Cover
Thickness and Offset
If the structural member has an architectural or fireproofing cover, select which surfaces are covered, and set the thickness and offset of the cover for each surface
Use cover material
Uses a material resource for the cover; select a material from the Resource Selector
Click the Geometry tab and set the parameters. The alignment graphic indicates where the Axis Alignment point is located.
Parameter
Description
Alignment
All associations and end conditions are based on the centerline that controls 2D/3D representations; the alignment can be shifted to allow accurate placement of the member
Profile Rotation
Specifies an angle to rotate the structural profile about the member’s centerline axis
Axis Alignment
Select the axis alignment
Offset Y’/Z’
Enter the offset, if needed
Elevation
The elevation of the start and end points can be explicitly set, in reference to the story or layer
Start/End Bound
Select the reference for the start/end point.
The elevation start and end bounds must be set separately for Column Insertion mode than for Linear Insertion and Poly Insertion modes.
Start/End Offset
Enter the start/end offset, if needed
Start and End Conditions
The offset, miter, and bevel of an end can be set manually or automatically derived from an associated structural member. Values entered for associated members apply as an addition to the automatically determined values.
Start/End Condition
Select whether to set the start/end conditions automatically by association, manually (custom), or to snap them to horizontal or vertical.
Start/End Offset
Set the offset, if needed to establish clean member connections; the offset is the distance to the end of the member geometry from the end of the centerline curve
Start/End Miter
Set a start/end miter angle of 70° or less
Start/End Bevel
Set a start/end bevel angle of 70° or less
Click the 2D Attributes tab and set the parameters.
Parameter
Description
Set Attributes By
Select whether to set attributes for the object in the Attributes palette, or by class, by line style, or by material (if a material is used).
Fills and line color may not be supported for line style.
Above/At/Below Cut Plane
If attributes are set by class or line style, set the attributes for the structural member. Structural members show uniform 2D attributes for the entire object, unlike other objects which can show separate attributes at the cut plane elevation.
The 2D attributes are determined by the attributes applied in the Structural Member Settings dialog box and the cut plane elevation, which is set either in the Object Info palette or by the design layer’s cut plane elevation.
Use Center Mark
Displays a center point marker at the end of the member; set the length of the marker and size of the gap, if needed. If attributes are set by class or line style, set the attributes.
Caps
Displays start and/or end caps for the member
When the cap is turned off for an end that is associated with the edge of another member, a gap is drawn in the edge of the connected member
Click the 3D Attributes tab and set the parameters.
Parameter
Description
Set Attributes By
Select whether to set attributes for the member and the cover in the Attributes palette, or by class or by material (if a material is used)
Diseño de miembros estructurales
Editing structural members
Concept: Material resources
Using materials
