Carriage bolts
Mode
Tool
Tool set
Carriage Bolt
Detailing
The Carriage Bolt tool and Carriage Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a carriage bolt (round head/round head square neck bolt):
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Series
Select inch or metric to display the appropriate nominal sizes
Bolt Type
Select the carriage bolt type
Size
Select the carriage bolt size
Length
For a custom length value, deselect Use Standard Length Increments and enter the length under the bolt head
Thread Style
(2D only)
Select the thread style
Automatically adjusts the length to the nearest increment based on size, per ASME standards; deselect to enter a custom length
Show Center Line
(2D only)
Draws the carriage bolt with center line(s)
Inserting fastener objects using the Fastener tool
Bolts
