Tapped holes
Mode
Tool
Tool set
Hole - Tapped
Detailing
Multiple drilled and tapped hole tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Both 2D and 3D tapped holes are available. The 3D tapped hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract solids).
To insert a tapped hole:
Click the tool and mode.
Parameter
Description
Screw Thread
Select the screw thread size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Tap Drill Size (Ref.)
Displays the tap drill size that corresponds to the selected screw thread
Hole Type
Select one of the hole types
Thread Depth
Specify the thread depth
Tap Drill Depth
Enter the tap drill depth value
Drill Point Angle
For Blind Hole types, enter the drill point angle
Use Custom Size
Uses custom diameter, thread pitch, and tap drill diameter values
Diameter
When Use Custom Size is selected, specify the diameter value
Pitch
When Use Custom Size is selected, specify the thread pitch value
Tap Drill Dia.
When Use Custom Size is selected, specify the tap drill diameter value
Thread Style
Select the 2D object thread style
View
Select the 2D object view
Show Profile Only
Displays just the outline of the 2D object thread. Available when using Detailed thread style only.
Show Center Line
Draws the 2D tapped hole object with center line(s)
Show Threads
Draws the 3D tapped hole object with threads
Drilled holes
