Creating basic stage stairs
Command |
Path |
Create Views |
Event Design |
Stairs or steps are usually required to provide access to the stage from the floor. The steps are automatically adjusted to meet the top of the stage. The basic stage stairs are based on the Stage Steps tool (see Inserting stage steps).
To add basic stage stairs:
Select the command.
The Create Stair dialog box opens.
Parameter |
Description |
Width |
Specify the width of the staircase |
Style |
Set the type of stair to create: Simple, Self-Adjusting, Frame Free-Standing, Solid Free-Standing, or Open Free-Standing |
Class |
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the stair in the None class to set the remaining attributes from the dialog box. |
Fill Color |
Sets the fill color for the stair |
Pen Color |
Sets the pen color for the stair |
Texture |
Opens the Resource Selector; double-click a resource to select it |
Click once in the drawing to set the stair position. Click again to set the stair rotation.
Stair parameters can be edited in the Object Info palette; see Inserting stage steps.
