Architect or SpotlightCreating seating sections
Tool
Workspace: Tool set
Seating Section
Architect: Furn/Fixt
Spotlight: Event Design
Use the Seating Section tool to design seating sections in a variety of configurations. You can create features such as rises and custom numbering plans, edit individual seats as needed to create exactly the arrangement you need, and then output the data to editable reports included with Vectorworks. Use the Aisle tool (see Adding aisles to seating sections; Spotlight required) to insert aisles that interact with the seating section. Quick editing capabilities allow you to change specific elements of the plan without using the processor resources to redraw the entire seating section.
You can use a seating section style from the Vectorworks content or create a custom seating section style to quickly create multiple seating sections with the same settings; see Concept: Plug-in object styles.
To draw a seating section object, either use the tool or create a closed 2D shape and then select the Create Objects from Shapes command (see Creating objects from shapes). If this command is used, a default focus line is placed and can be moved manually to the desired location.
Use the Data Tag tool after creating a seating section to add a label; see Adding data tags and labels.
The Seating Section tool offers the following modes:
Mode
Description
Create from Shape
Converts an existing polyline, polygon, rectangle, circle, or arc to a seating section. The attributes of the original shape are applied to the seating section.
Oval
Creates a round seating section
Rectangle
Creates a rectangular seating section
Polyline
Draws a seating section using the selected polyline creation options
Polyline creation options
Selects the method for drawing the polyline upon which the object is based; see Creating polylines
Style
Opens the Resource Selector to select a resource for placement; double-click a resource to activate it
Preferences
Sets the default parameters that are used for each new seating section
To create a seating section:
Click the tool and mode.
Do one of the following:
Click Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the Seating Section Preferences dialog box and specify the tool’s default parameters as described in Seating section settings.
The parameters can be edited later in the Object Info palette as described in Editing seating sections, or in the Seating Section Settings dialog box.
If using Create from Shape mode, move the mouse over a previously drawn shape until it is highlighted. Click to select it.
If using Rectangle, Oval, or Polyline mode, click to draw the bounding shape for the seating section.
The cursor changes to indicate placement of a focus line, and layout lines preview the seating angle for the focus line.
Click twice to place the seating section’s focus line. The first click controls the angle of straight seats or the radius of curved seats. The second click controls the focus point of the seats. When Display Focus Line is selected in the Object Info palette, the focus point end of the line is indicated by an arrow.
If the Angle of Seating is set by the style, the specified value sets the seating angle, and a focus line is automatically drawn in the middle of the seating section. To change the seating angle, edit the style settings on the Seating section settings: Angle pane.
Optionally, create a style resource from an unstyled object (see Custom plug-in object styles without catalog options).
To associate the seating section with an aisle object (Spotlight required), put the seating section and the aisle on the same layer or in the same group; see Adding aisles to seating sections. This association means that if one of the objects is resized, reshaped, or moved, the other object updates automatically. The association between objects lasts only as long as the seating section and aisle physically overlap.
The settings are grouped into several panes of related parameters, which are listed on the left side of the dialog box. These parameters vary depending on whether a standard or curved seating type is selected. Select each pane and specify the parameters.
Every pane of the Seating Section Settings dialog box displays a preview of the seating section with the current settings; the preview updates dynamically as the settings are edited. If multiple seating sections are selected, the preview displays the first one in the stacking order.
You can create plug-in objects, such as the seating section, with a combination of parameters that are determined by the style or by instance, and then optionally save them as a plug-in object style. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing.
Parameter
Description
(Seating Type)
Select whether to create a Standard (straight) or Curved seating section; depending on the settings, curved seating sections can curve into a complete 360° circle
Use Style
To create a custom seating section, leave the Unstyled setting. To use an existing seating section from the resource libraries, click Use Style; from the Resource Selector, double-click a resource to select it.
Convert to Unstyled
If Use Style is currently set to a style, select this option to convert the object to unstyled; the current values are retained, but all parameters on all panes are set to By Instance to allow editing
By Style/Instance
A graphic indicates whether each parameter is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. By Style/Instance settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style.
Top/Plan Preview
Dynamically displays a Top/Plan preview of the seating section with the currently selected parameters
Use actual symbols
Displays the selected Seating Symbol in the preview; if deselected, the preview displays the symbol’s bounding box and center point
Seating section settings: Arrangement pane
Parameter
Description
Alignment Type
(Standard seating type only)
Select the seating alignment with reference to the Primary Fill Direction and Secondary Fill Direction; in the examples below, the fill direction settings are Left to Right and Top to Bottom
Shift Rows: seats are aligned with the boundary
Align Rows: seats in each row are aligned directly behind one another
Offset Rows: every other row is offset by half the width of the first seat
Distribute Rows: seats fill the boundary edge-to-edge; spacing is adjusted to distribute seats evenly in each row, with Seat Spacing treated as the minimum value
Placement
Seat Spacing
Specify how far apart to space the seats in a row; spacing is based on the symbol’s bounding box and insertion point
Row Spacing
Specify how far apart to space the rows; spacing is based on the symbol’s bounding box and insertion point
Distance Measurement
Select whether to measure the Row Spacing from the back leg of one row to the front leg of the next, or from the front leg of one row to the front leg of the next
Allowable Distance Past Boundary
If the seating is permitted to go past the seating section boundary, specify by how much
Select whether to fill the seating section from Left to Right, Right to Left or Center Out for straight sections, and Clockwise or Counter Clockwise for curved sections
Select whether to fill the seating section from Top to Bottom, Bottom to Top, or Center Out for straight sections, and from Inside to Outside or Outside to Inside for curved sections
Start Angle
For curved seating sections, specify where the seats start to be placed
Rise
If the seating section is to rise from the front to the back, select how to calculate the rise, and specify the height
(Symbol list)
You can specify more than one symbol in the section
Displays the symbols in the fill order for the seating section, with reference to the Primary Fill Direction and Secondary Fill Direction.
This is a static field that displays the order. To change the order, you must click each row and then select a different symbol for the row.
Symbol
Displays the current symbol name; to change the symbol, click on the row and then select a new symbol from the Resource Selector
Alignment in Row
Select whether to align the symbols by the top, center, bottom, or insertion point
Add
Click to add a row to the bottom of the list. The active symbol is used by default; select a new symbol from the Resource Selector.
Remove
Click the row with the symbol to remove, and then click to remove the selected symbol from the seating section
Seating Symbol
Displays the currently selected resource; to change it, locate the desired resource, and double-click to activate it.
Alternatively, select a symbol to use as the basis for a new seating symbol with customized attributes, or create your own seating symbol, as described in Seating symbol specifications.
Customize
Customizes the selected seating’s default attributes, creating a new hybrid seating symbol; see Customizing seating symbols
Seating section settings: Section Information pane
Parameter
Description
Name
Name the seating section; Vectorworks automatically assigns each seating section a unique ID, so this name does not have to be unique in the document
Number seats
Numbers the seats; for a table-and-chair symbol, the table is numbered
Numbering Direction
Select the direction in which to number the seats
Restart on next row
Starts each row with the Start at value; if deselected, the numbering is continuous throughout the section
Start at
Specify the first seat number; alphanumeric values are allowed
Increment
Specify the seat numbering increment
Number rows
Numbers the rows; for a table-and-chair symbol, the table is numbered
Numbering Direction
Select the direction in which to number the rows
Start at
Specify the first row number; alphanumeric values are allowed
Increment
Specify the row numbering increment
Separator
Select the separator between the row number and seat number in the display
Display Row Number
Select whether to display the row number on every seat, or on one or both ends of the row
Seating section settings: Limits pane
Parameter
Description
Seats per row
Select if there is a maximum number of seats allowed per row, and specify the limit
Rows per section
Select if there is a maximum number of rows allowed per section, and specify the limit
Total seats
Select if there is a maximum total number of seats allowed per section, and specify the limit
Minimum seats per row
For curved seating sections, select if there is a minimum number of seats allowed per row, and specify the limit
Draw loci
Draws loci where seats could have been placed within the boundary but were not placed due to numerical limits
If the seating section object is four-sided and all four corners are 90°, you can specify an angle for the seating within the boundary.
Parameter
Description
Angle seating
Angles the seating within the boundary. Enter a value in the Angle of Seating field or drag the slider to specify an angle between 0 and 180°. For a Curved seating type, each seat turns individually, rather than angling the entire row.
The seating angle is connected to the seating section’s focus point. As the Angle of Seating value is changed, the focus point automatically moves to maintain the logical link. Likewise, if the focus point is moved, the Angle of Seating value automatically updates.
Angle Based on
Specify whether the angle is based on the left or right side of the boundary
Adjust boundary with angle
Reshapes the boundary to conform to angled seating; deselecting this option may result in the loss of seats
Seating section settings: Classes pane
Parameter
Description
Class Prefix
Specifies an optional default root class naming standard for all seating section parts
Assign Default Classes With Prefix
Sets the class names for all seating section elements to the standard, using the Class Prefix if there is one, so that they are sorted together
Seating section parts
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Seating Section Class> to place the part attributes in the same class as the seating section object.
