Converting old hoists
Command
Path
Convert Old Hoists
Tools > Utilities
Hoist and dead hang objects that were created with the Hoist tool and Insert Dead Hang tool prior to Vectorworks 2021 can be converted to the current hoist for improved performance.
To convert old hoist or dead hang objects:
Select the objects to convert, and select the command.
Data from the old hoist or dead hang object is transferred to the new hoist symbol, and the Braceworks connections are maintained (Braceworks required). The geometry for the low hook and the high hook is converted to use the new symbol geometry.
The following field mapping is used in the Object Info palette.
Legacy hoist field
Legacy dead hang field
New hoist field
Hoist Number
ID
Hoist ID
Hoist Label
Name
Hoist Name
Location
N/A
Position
Chain Runners
N/A
Chain Runners
Speed
N/A
Speed
Phasing
N/A
Phasing
Voltage
N/A
Voltage
Hoist Wt with Chain
Weight
Total Weight
Distro/Port
N/A
Distro/Port
Allowable Weight
Capacity
Capacity
Reaction Force
Reaction Force
High Hook Force, Low Hook Force
Total Point Load
N/A
High Hook Weight Equivalent
Measure From
N/A
Origin
Realistic Chain
N/A
Realistic chain
Placing hoists
Hoist properties
