Inserting house rigging points automatically
Command |
Path |
Insert House Rigging Point at Selection |
Spotlight > Rigging |
A house rigging point can be added automatically to an existing structural element—if, for example, a bridle leg lacks an assigned rigging point. In addition, the command can easily add a house rigging point to any selected object or objects, including symbols. You can select several symbols, and the command adds a house rigging point to the insertion point of each symbol.
To insert house rigging points on selected objects:
Select the objects, such as support beams, and select the command.
The Select Symbol dialog box opens.
Select a house rigging point symbol from the Resource Selector.
A house rigging point is inserted on each selected object.
