Design SuiteImporting 3ds
Command
Path
Import 3DS (3D only)
File > Import
When importing a 3ds file from Autodesk 3ds Max software, version 3.0 and higher, specify how the drawing components will be represented in the Vectorworks file.
To import a 3ds file:
Select the command and then the file to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Import 3DS Options dialog box opens; the options available depend on the contents of the file being imported.
Specify the file import options.
Parameter
Description
Import materials
Select whether to assign fill colors from the imported objects according to the colors of the materials of objects when selected
Import transparency and image data as Renderworks textures
Imports texture and transparency materials as Renderworks texture resources
Create Renderworks textures for all materials
Creates Renderworks textures for all imported materials from the input file
Import mesh objects
Imports each mesh object defined in the 3ds file as either a group of mesh objects or 3D polygons
Import as Vectorworks mesh object
Imports all geometry as a group of mesh objects
The 3DS file format does not contain smoothing information. The 3DS import will set document smoothing to the created mesh objects.
Import as groups of 3D polygons
Represents all imported geometry as a group of 3D polygons
Preserve texture assignment and mapping
If Import materials is selected, and you are importing geometry as polygons, specify whether textures and texture mappings are applied to imported 3D polygons to preserve their overall appearance
Scale
Opens the Import 3DS Scale dialog box, for specifying a scale to apply to all imported objects; see Scaling 3ds objects for import
Import as symbol
Imports the file contents as a symbol definition in the Resource Manager; for more information, see Resource Manager and Concept: Vectorworks symbols
Import light objects
Imports light objects from the 3ds file
Import spot light
Select this option to import spot lights from the 3ds file as Vectorworks spot lights
Import omni light
Select this option to import omni lights from the 3ds file as Vectorworks point lights
Import camera objects
Imports camera objects from the 3ds file
Import active camera only
Imports only the active camera from the 3ds file, and sets the current view to the camera view
Create saved views for each camera
Imports all camera objects from the 3ds file, and creates a saved view in the Vectorworks file for each
The scaling is applied to all imported objects.
To scale 3ds objects during import:
From the import dialog box, click Scale.
The Import 3DS Scale dialog box opens.
Choose whether to scale the object(s) by custom dimensions or by scale factor.
Parameter
Description
3DS Model Width/Height/Depth
Displays the original dimensions of the object(s) selected for import or export; if there are multiple objects, the scaling center is the center of the selection bounding box
Custom
Allows entry of custom dimensions for imported or exported objects in the Desired Width, Desired Height, and Desired Depth fields. Select Maintain Proportions to automatically adjust the proportions when a custom width, height, or depth is entered.
Scale
Allows entry of a scaling factor to be applied to imported or exported objects. Either select a Scale from the list, or select Custom from the top of the list and enter a Custom Scale value. When the scale factor changes, the dimension values also change to show the exact size of the selection bounding box for the given scale.
Editing mesh objects
