Changing the panel schedule format
Command |
Path |
Create Panel Schedule |
Tools > Reports |
To format a panel schedule:
Select the command.
The Create Panel Schedule dialog box opens.
Select the panel schedule and its location.
Click Edit.
The Schedule Formatting dialog box opens. Select the schedule to format from the Schedule list. A list of available fields and, if applicable, the schedule’s printed name displays.
Parameter |
Description |
Schedule |
Select the schedule to format |
Printed Name |
Specifies the name that is printed on the schedule |
Available Fields |
Lists all possible schedule column items |
Schedule Columns |
Lists, in order, all included schedule columns |
Move > |
Moves a selected item from the Available Fields list to the Schedule Columns list |
< Move |
Moves a selected item from the Schedule Columns list back to the Available Fields list |
Move Up/Move Down |
Moves a selected item in the Schedule Columns list to adjust the list order |
Printed Schedule Width |
Specifies the total width of all schedule columns when printed |
Column Headers |
Displays the current font, style, and size for header information in the schedule. Click Change to edit the font format. |
Body |
Displays the current font, style, and size for body text in the schedule. Click Change to edit the font format. |
The columns shown in the Column Order list appear in the schedule in order.
Panel schedule formatting is stored as a worksheet named “Panel Schedule Fmt.” This worksheet can be imported, using the Resource Manager, into other files where the same formatting is desired.
Click OK to return to the Create Panel Schedule dialog box. Click OK to place the schedule with the specified format.
