Panel scheduling and diagramming
Creating a panel schedule
Command |
Path |
Create Panel Schedule |
Tools > Reports |
The Create Panel Schedule command generates panel schedules based on the circuiting information assigned to the file. If necessary, modify the dimensions and layout of the panel to conform to existing office standards.
To create a panel schedule:
Select the command.
The Create Panel Schedule dialog box opens. Specify the panel schedule criteria.
Parameter |
Description |
Panel list |
Select a panel from the list of available panels for creating the schedule |
Place in worksheet |
Places scheduling information in a worksheet resource named with the panel name |
Place in Document |
Places a panel schedule on the drawing |
Choose Schedule |
Indicates the location for placing the panel schedule on the drawing |
Layer |
Specifies the layer for placing the schedule |
Class |
Specifies the class for the schedule |
Panel Style |
Select the panel formatting style from the list |
Edit |
Changes the panel schedule formatting |
If you selected the option to place the schedule on the drawing, click at the desired location.
If you selected the option to place the panel schedule in a worksheet, a worksheet is created with the panel name.
If circuiting changes are made, delete the outdated panel schedule and repeat the create panel schedule procedure.
