The Object Info palette: Render tab
Use this tab to manage textures on 3D objects.
If you selected multiple objects, select either Multiple Edit or Individual Edit mode, as described in Editing multiple objects. See Managing object textures from the Object Info palette for information about how to use the Render tab.
Editing textures and shaders
Sketch rendering
Applying a sketch style to an object
