Reshaping NURBS curves
Tool
Tool set
Shortcut
Reshape
Basic
- (hyphen)
The Reshape tool allows you to move, add, and delete vertices to reshape NURBS curves. Transform mode permits free-form movement for more fluid reshaping.
Mode
Description
Move Vertex
Changes the location of one or more selected vertices
Transform
Uses a 3D dragger to transform vertices in a variety of ways depending on the additional modes selected; see Reshaping NURBS curves with Transform mode
Add Vertex
Adds a vertex to the NURBS curve
Delete Vertex
Deletes a vertex from the NURBS curve
Change Vertex
Toggles an existing vertex between a corner vertex and smooth vertex
Working Plane Constrain
(Move Vertex and Add Vertex modes only)
Moves the selected vertices on a working plane
X-axis Constrain
Moves the selected vertices along the X axis
Y-axis Constrain
Moves the selected vertices along the Y axis
Z-axis Constrain
Moves the selected vertices along the Z axis
Translate and Rotate
(Transform mode only)
Uses the Translate and Rotate 3D dragger to manipulate vertices to reshape and rotate the selected object
Scale
Uses the Scale 3D dragger to change the scale of part of the selected object
Re-position
Repositions the 3D dragger without affecting the selected object.
Because free-form movements are performed relative to the 3D dragger's center, some operations can only be completed if the 3D dragger is repositioned away from a selected vertex.
Align to Curve
Keeps the Z axis of the 3D dragger aligned to the NURBS curve's normal at the selected vertex
Align to Working Plane
Keeps the 3D dragger aligned to the working plane; see Concept: Understanding the working plane
Reshaping NURBS curves with Move Vertex mode
To move a vertex:
Mode
Tool
Tool set
Shortcut
Move Vertex
Reshape
Basic
- (hyphen)
Select the NURBS curve to reshape.
Click the tool and mode, and then click a constraint mode.
Move the cursor over the NURBS curve; when the cursor is over a vertex, the cursor changes to an unfilled, four-way arrow.
Click a vertex to select it. To select multiple vertices at one time, click with the Shift key pressed or click and drag to create a marquee around the desired vertices.
To move multiple vertices, the curve must be a single, smooth continuous NURBS curve; composed NURBS curves do not allow multiple selection.
As you move the cursor, the change previews.
Click to place the vertex and reshape the NURBS curve.
Reshaping NURBS curves with Add Vertex mode
To add a vertex:
Mode
Tool
Tool set
Shortcut
Add Vertex
Reshape
Basic
- (hyphen)
Move the cursor to an existing vertex near the location where the new vertex is to be added. The cursor becomes an arrow with two diamonds when a vertex can be added, and the adjacent segment of the curve is highlighted.
Click the existing vertex and then drag the cursor to the desired location for the new vertex.
Click to add the vertex.
Reshaping NURBS curves with Delete Vertex mode
To delete a vertex:
Mode
Tool
Tool set
Shortcut
Delete Vertex
Reshape
Basic
- (hyphen)
Click the tool and mode.
Click the vertex to delete.
Reshaping NURBS curves with Change Vertex mode
To toggle a vertex between a corner vertex and a smooth vertex:
Mode
Tool
Tool set
Shortcut
Change Vertex
Reshape
Basic
- (hyphen)
Click the vertex to toggle.
Functionality similar to the Reshape tool is available from the Object Info palette Shape tab; see Editing vertex-based objects.
Creating NURBS curves
Reshaping objects
