Omniverse Connector preferences
Mode |
Tool |
Tool set |
Preferences
Omniverse Connector (Windows only)
Visualization |
The Omniverse Connector Preferences dialog box sets the default parameters for both Publish to Omniverse mode and Send to View mode, and the Omniverse View version to use when sending to view.
Click the tool and mode.
The Omniverse Connector Preferences dialog box opens.
Set the parameters.
Parameter |
Description |
Export USD Options |
These options can also be set or changed while publishing to Omniverse, in the USD Export Options dialog box accessed from the Publish to Omniverse dialog box |
Geometric Detail |
Set the geometric detail level for 3D objects with curved surfaces. This setting is important for both export speed and for rendering performance in the selected export program. Low values result in smaller files and faster performance, but objects become more faceted. Higher values create larger files and render more slowly, but curved objects appear smoother. |
Scene Graph Organization |
Organizes the exported model by Vectorworks layer or by texture. Organizing by exported texture can be useful for other modeling and rendering applications. |
Combine objects |
For scenes organized by texture, combines objects with the same texture into larger meshes; this will improve performance |
Metadata |
Select whether to include Vectorworks IFC metadata or record format data. These data are used in USD-based applications that require non-graphical data, or in programs that query and/or report BIM data. Inclusion of record and IFC data creates larger Omniverse models and may result in slower performance. Basic data such as object name, object type, plug-in universal name, Vectorworks universal ID, class, and layer are automatically included in the USD scene. |
Send to View Settings |
View |
Specifies the location of the Omniverse View installation (.exe or .bat file) to use with Send to View mode. The default location is automatically populated the first time the application is used, but if multiple versions are installed, you can browse to select a different location. |
Server |
Select the Nucleus server to use, from the list of servers available for Omniverse export; click Modify to manage the list of servers |
