Architect or LandmarkSite model source data
There are five commands available to input source data into a drawing for the development of a site model; each uses a different type of source information.
Import Survey File
2D Polys to 3D Source Data
3D Polygons to 3D Loci
Grid Method Entry
Extract 3D Loci from Point Cloud
In addition, stake objects, 3D loci, or 3D polygons can be used directly as the source data for the site model. No conversion is necessary before using this type of source data.
The Modify by Record command can convert 2D polygons or polylines with attached record elevation data directly to 3D polygons at the proper elevation. See Modifying objects by record value.
Before you create the site model, check the source data with the Validate 3D Data command to ensure that a valid site model will be created.
Importing source data from an external file
Adding source data with 2D polygons or polylines
Converting 3D polygons to 3D loci
Adding source data by grid method entry
Extracting 3D loci from a point cloud
Validating 3D source data
Simplifying 3D polygons
