Importing source data from an external file
Command
Workspace: Path
Import Survey File
Architect: AEC > Survey Input
Landmark: Landmark > Survey Input
Site model source data can be generated by tabular coordinate information from an external file. This file must be a text file with fields delimited by separators in one of the formats available.
To import survey information for use as source data:
On the layer to receive the imported data, select Active Layer Scale from the drawing context menu to set the scale, or select the File > Document Settings > Document Setup command (see Document setup).
Select the command.
The standard Open File dialog box opens. Select the file to import.
The Import Survey File dialog box opens. Specify the file format options, scrolling through each line of data if necessary, and set the file import options.
Parameter
Description
Data from selected file
Displays the first line of data in the selected file
Line #
Displays the line number of the data displayed; click the < or > button to check each line in the file
Survey File format
Specifies the File Type of the import file:
Excel: .xls or .xlsx file; if the spreadsheet contains multiple sheets, the first sheet will be imported
Tab delimited: File with tab delimiters between fields
Other: File in any other format; also enter the Delimiter Character that separates the fields
Survey Data
Data Format
Specifies the format of the data to import
Units
Specifies the units from the imported file
Import Options
Create Stake Objects
Places stake objects to represent each 3D point in space, with text to display the elevation when in Plan view (see Inserting stake objects). Stake objects include the appropriate Easting, Northing, and Elevation values.
For big sets of source data, creating large numbers of stake objects could result in performance issues. It may be preferable to create 3D loci instead.
Create 3D Locus Objects (imports only location)
Places 3D loci, which contain only location information (X, Y, and Z coordinates)
As each line of the file is read, either 3D loci or stake objects are inserted into the drawing at the coordinates specified by the file. If this is the first time a stake object has been inserted in the drawing, the Object Preferences dialog box opens. Accept the defaults.
Creating the site model
Modifying objects by record value
