Specifying server options
The system administrator can control the module and the licensed user options; for example, some users may not be allowed to borrow Vectorworks, or may only borrow it for shorter periods of time than other users. The administrator can also set report log and debug log file options.
The most convenient way to manage user permissions and modules is to use the System Menu for Configuring access permissions. It is also possible to use the browser interface, as described below, although this is not recommended.
If there are many users that will not be allowed to borrow the software, instead of excluding each one, use INCLUDEALL_ROAM to allow only specific users to borrow.
To specify and edit the module, user, or log file options:
From the main Server Administration screen, click Status.
The server status pane displays.
In the Options column of the ISV Servers table, click vektorwrx.
The Edit ISV Options screen opens.
Using the syntax described in Server syntax, specify or edit the user options.
In the syntax and examples, user, host, internet, group, host_group, and internet_group can be specified interchangeably when setting up permissions for a client or groups of clients.
Command
Description
Syntax
roam_max_days
Restricts the borrowing feature for a certain number of days (normally, up to 30 days) and for certain modules.
To prevent borrowing, use a negative number.
ROAM_MAX_DAYS days module
Example: ROAM_MAX_DAYS 3 architect
ROAM_MAX_DAYS -1 landmark
Exclude
Restricts the use of a module for the specified client
EXCLUDE module user name
Example: EXCLUDE landmark user sam
Include
Restricts the use of a module for any clients not specified
INCLUDE module group group_name
Example: INCLUDE spotlight group designers
Excludeall_roam
Restricts borrowing for certain clients
EXCLUDEALL_ROAM user firstname_lastname
Example: EXCLUDEALL_ROAM user susan_rodriguez
Includeall_roam
Allows borrowing for certain clients
INCLUDEALL_ROAM group group_name
Example: INCLUDEALL_ROAM group architects
Reserve
Reserves licenses for critical clients
RESERVE number module user user_name
Examples: RESERVE 1 spotlight user elena
RESERVE 3 architect group engineers
Max
Limits the maximum number of licenses checked out per client
MAX number module user firstname_lastname
Example: MAX 3 landmark host_group designers
Debuglog
Opens the Debug log for the ISV server
DEBUGLOG “file_path_file_name”
Example: DEBUGLOG “Log\dlog.txt”
Debuglog +
Creates a different Debug log for each ISV server, automatically appending the log information rather than overwriting the log; this can also be specified as a startup option. See Server startup options.
DEBUGLOG “+file_path_file_name”
Example: DEBUGLOG “+Log\dlog.txt”
Nolog in
Nolog out
Nolog denied
Specifies that the server won’t log information about license check ins, check outs, or denied licenses in the Debug log
NOLOG type
Example: NOLOG denied
Reportlog
Saves license usage information to a log file
REPORTLOG “file_path_file_name” type
Windows example: REPORTLOG “C:\My Reports\Reportlog.txt” detailed
Mac example: REPORTLOG “My Reports/Reportlog.txt” std
Reportlog +
Creates a different Report log for each ISV server, automatically appending the log information rather than overwriting the log.
REPORTLOG “+file_path_file_name”
Rotate
Saves and closes the current report log, creating a new log
ROTATE [daily|weekly|monthly|#days]
Example: ROTATE daily
Click Update Options.
The options are saved in the vektorwrx.opt file, which is located in the same network license folder as the RLM software: ProgramData\Vectorworks Site Protection folder on Windows or on Mac, /Library/Application Support/Vectorworks Site Protection/
Server Status screen
Main server administration screen
The Report log
The Debug log
Requiring server passwords
Controlling RLM options
