Saving a file
| Command | Path | Shortcut |
| Save Save As Save A Copy As | File | Ctrl+S (Windows) Cmd+S (Mac) |
To save a file do one of the following:
To save the current file, select the Save command.
To save the file with a different name, select the Save As command.
To save a copy of the file and continue to edit the original file, select the Save A Copy As command.
To save the file as a template for future files, see Concept: Templates.
Automatically saving files
The autosave feature automatically saves the current file after either a specified number of minutes or a specified number of operations, as defined in the Autosave pane of the Vectorworks Preferences dialog box. See Vectorworks preferences: Autosave pane for more information.
If the Confirm before save preference is selected, a confirmation dialog box opens before the autosave is performed. The information that displays in this dialog box depends on the settings selected in Vectorworks preferences.
| Parameter | Description |
| Yes | Saves the file; if the document has not been saved, the Save dialog box opens to name the file first |
| No | Cancels the save operation and resets the autosave counters |
| Settings | Opens the Vectorworks Preferences dialog box to edit the autosave parameters; select Don’t backup this document for the remainder of the session to disable the autosave feature for the active document for the remainder of the session |
When the save is complete, the message Autosave complete displays in the lower right corner of the window; the message clears when you click the mouse.
