Editing plug-in object styles
Editing a plug-in object style changes every instance in the file that uses that style.
To edit a plug-in object style:
Open the <Object> Style dialog box or Plug-in Object Style dialog box in one of these ways:
In the drawing area, right-click on a plug-in object that uses the style to edit, and select Edit Plug-in Style from the context menu.
From the Resource Manager, right-click on the style to edit, and select Edit from the context menu.
From the Object Info palette, select Edit Style from the Style list.
Set the parameters as described in Creating plug-in object styles.
Changing plug-in object styles from the Object Info palette
