Design SuiteL wall component joins
Mode
Tool
Tool set
Shortcut
L Join
Component Join
Building Shell
Alt+Shift+J (Windows)
Option+Shift+J (Mac)
The L Join mode joins the closest ends of two wall components to create a corner. Both component lengths are extended or shortened, as necessary, until they meet cleanly.
To join wall components with the L Join mode:
Click the tool and mode.
Select the component within the wall segment to join.
Select the second wall segment to join. The component to be joined is highlighted.
Repeat steps 2 and 3 for each component within the wall segment that needs to be joined.
Joining wall components
T wall component joins
Capped wall component joins
Hiding wall components
