DMX transforms
Use DMX transforms to scale, rotate, and move selected items in the scene. Scaling and movement are independent from the object’s rotation. Scaling does not apply to lighting devices.
To transform objects in DMX mode:
Select one or more lighting devices or objects.
To transform multiple selections at once, you can group them in a layer; see Organizing the scene contents. When a layer is transformed, all items contained in that layer are transformed accordingly. A transformed lighting device's pan and tilt are relative to the transformed position.
To significantly improve performance for DMX transforms, disable shadows from the Basic: Graphics tab or Advanced: Graphics tab. If shadows are needed, set Dynamic Shadows to None from the Advanced: Graphics tab; shadows will be disabled only for transformed objects.
In the Properties palette, select DMX for the Xform Mode.
Scale, move, and/or rotate the selected objects using the DMX XForm parameters.
Click to show/hide parameters.Click to show/hide parameters.
Parameter |
Description |
XForm Mode |
Select DMX to enable DMX transforms |
DMX XForm |
Expand the DMX XForm heading to access the parameters |
XForm Universe |
Enter the universe |
XForm Channel |
Enter the DMX address |
XForm Delta X/ XForm Delta Y/ XForm Delta Z |
Enter the XForm Delta values (in inches) to specify the direction and magnitude of movement. The movement is not affected by the item’s rotation. The direction is relative to the item’s local coordinate space. Delta X controls the range of lateral movement. Delta Y controls the range of upward/downward movement. Delta Z controls the range of forward/backward movement. The Position X/Y/Z values in the Properties palette determine the selected items’ starting position. Set the DMX profile for the desired movement. 50% indicates the center of the range of movement.
XForm Rotation Axis |
Select the rotation axis, or select None. Set the DMX profile for rotation. Rotation occurs around the local origin, not the world origin.
There are three “dead zones” where no rotation occurs in the Continuous Rotation channel: 0%, 49–51%, and 100%. The rotation is clockwise at 48–1% (where the effect increases as DMX value decreases) and counter-clockwise at 52–99%. |
XForm Rotation Delta |
Sets the maximum angle of index rotation |
XForm Rotation Rpm |
Set the maximum speed of continuous rotation |
XForm Scale X/ XForm Scale Y/ XForm Scale Z |
Enter scale factors for each axis to scale the selected object along that axis. Scaling is not affected by the object’s rotation. Set the DMX profile for scaling.
