Deleting scene objects and fixtures
Command |
Path |
Delete Selected Delete Selected > All Delete Selected > Lasers Delete Selected > Lighting Devices Delete Selected > Projectors |
Context menu |
You can easily delete objects and fixtures from the scene.
If the selection contains only one type of item, delete them with the Delete Selected context command.
If a mix of object types is selected, the appropriate context command will delete certain types of objects, or delete them all.
To delete objects and/or fixtures from the scene:
Select the objects to delete.
Do one of the following:
From the Scene Graph palette, select the object, laser, and/or lighting device to delete. Multiple objects can be selected by selecting a layer, or by pressing the Shift key or the Ctrl (Windows) or Cmd (Mac) key while clicking on the items.
From the Scene window, select the object, laser, and/or lighting device to delete. Multiple objects can be selected by pressing the Ctrl (Windows) or Cmd (Mac) key while clicking on the items.
Selected objects are highlighted in the scene.
Select the appropriate command.
Delete Selected deletes selected items of all one type.
Delete Selected > All deletes all of the selected items.
Delete Selected > Lasers deletes all of the lasers in the selection.
Delete Selected > Lighting Devices deletes all of the lighting devices in the selection.
Delete Selected > Projectors deletes all of the projectors in the selection.
