Import options
When certain file formats are opened or merged in Vision, the Import Options dialog box opens. The available options depend on the file format.
Parameter
Description
Mesh Smoothing
Select how mesh smoothing is applied to imported objects.
Imported: Determines whether objects appear faceted or smooth based on the normals in the imported file (the normals are not recalculated).
Custom Crease Angle: Determines whether objects appear faceted or smooth based on the specified Crease Angle (the normals are recalculated).
None: Forces all objects to appear flat or faceted (the normals are recalculated).
Crease Angle
When Custom Crease Angle is selected, enter the desired angle to smooth all mesh objects rendered with OpenGL; enter a higher value for smoother surfaces (range: 0–180)
Units in File
Select the units for the imported file; this affects the size of the imported objects
Use Fixture Types from
(MVR only)
Select the type of fixture to use: GDTF or Vision. It is also possible to use both types in a scene.
The fixture import depends on the Use Fixture Types from setting, as well as the fixture mode settings made in Vectorworks. See Setting the fixture type for MVR import.
When GDTF fixtures are imported, some of their parameters are disabled on the Properties palette, and all GDTF fixtures are disabled in the Patch dialog box.
Truss Texture
(MVR only)
Select the truss texture, or select Imported to apply truss textures from the imported file
Coordinate System
Select the coordinate system for the imported file:
Vectorworks (right-handed, Z-up, Y-forward)
Vision (left-handed, Y-up, Z-forward)
Select Vectorworks if the file was exported from the Vectorworks program.
Flip moving lights
Rotates all moving lighting devices by 180° on the X axis, so Vectorworks content can be oriented correctly in Vision
Update existing MVR objects
(MVR only)
Updates the open scene file without duplicating the existing geometry
Setting document preferences
Data exchange for previsualization
Opening files
Merging files
Saving and exporting files
