Resetting video inputs
You can reset one or more video inputs, to change the inputs assigned to textures.
Resetting a single video input
Command
Path
Reset Video Input
Viewport context menu
To reset a video input:
Select an object with the texture input to change, and select the command. All objects with the selected texture display a checkerboard pattern for identification.
The Select Video Input dialog box opens.
Select a video input for the specified texture, as described in Assigning video inputs.
All objects with the selected texture display the new input.
Resetting multiple video inputs
Command
Path
Reset Video Inputs
Render
To reset one or more video inputs:
Select the command.
An alert indicates the status of video inputs in the file. If all inputs are available, click OK. If some inputs are faulty, address the issues as described in Managing assigned video inputs.
The Select Video Input Texture dialog box opens, listing the textures in use.
Select a texture to change; Preview displays the assigned video input. All scene objects with the selected texture display a checkerboard pattern for identification.
Click Reset.
You are prompted to reset more video inputs. Click Yes to continue changing inputs, or click No to stop.
The Scene Graph palette
Assigning textures
Modifying video inputs
