The Working Planes palette
Command
Path
Shortcut
Working Planes
Window > Palettes
Ctrl+Shift+K (Windows)
Cmd+Shift+K (Mac)
The Working Planes palette lists working planes that have been saved while working on a drawing; the active layer plane is always listed also. The palette allows you to save new working plane positions, and to edit, duplicate, delete, activate, and select existing working planes. Combine these features with the working plane controls on the View bar, the working plane commands on the Modify menu, the Set Working Plane tool, and the Align Plane tool to accurately control the placement and alignment of objects in 3D space.
To manage working planes in the Working Planes palette:
Select the command.
The Working Planes palette opens.
Click the Utility menu on the palette's title bar.
Alternatively, right-click on the palette to access the context menu.
Menu/command
Action
New
Opens a dialog box to save the working plane that is currently active
Edit
Opens a dialog box to edit the working plane selected in the list
Duplicate
Duplicates all working planes selected in the list
Delete
Deletes all working planes selected in the list
Activate
Activates the working plane selected in the list. Alternatively, double-click an item on the list to activate it.
Select
Activates the working plane selected in the list and selects it in the drawing area. The grip handles display to allow you to edit the plane's position.
Select the desired command.
Working plane modes
Working plane commands
