SpotlightModifying truss symbol data
Command
Path
Customize Truss Symbol Data
Context menu
To create a custom truss, advanced users can edit a truss symbol’s default data. The truss symbol definition is updated, affecting the current symbol instances and future symbol placement.
Changing the default manufacturer data is generally not recommended.
To modify the truss symbol data:
Select a truss symbol instance in the drawing, and select the command. Multi-selection does not apply.
The Truss Properties dialog box opens for Setting custom truss parameters.
Edit the data as needed.
An alert opens if the edits will change any truss geometry in the drawing. Click Yes to confirm the changes. Click No to restore the previous data specifications.
The truss symbol definition is updated.
Concept: Vectorworks symbols
Placing trusses
Creating a custom truss symbol
Specifying cross section data
Connecting rigging objects
Concept: Creating a connected rigging system
