SpotlightPlacing trusses
Tool
Tool set
Truss
Rigging/Braceworks
The Truss tool and the Magnet tool share the same position in the Rigging/Braceworks tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The Truss tool places a section of truss on the drawing. Depending on the resource selected, the truss may be a straight, curved (or circular), hinge, or corner element.
You can place one truss at a time, or place multiple straight trusses, to create a truss line. Trusses can be inserted horizontally, vertically, or at a custom hanging angle. In Auto Connect mode, the trusses connect to existing trusses, forming a system. When Auto Connect is disabled, the trusses do not connect to existing systems.
Use the Data Tag tool to add a label to the truss; see Adding data tags and labels.
Mode
Description
Auto Connect
When enabled, connects the inserted truss to the current truss system with geometrical precision; also generates a preview of connected trusses that are being moved
Truss symbol
Select the truss to insert
Single Insertion
Inserts a single truss object on the guideline
Distributed Insertion
(straight truss only)
Inserts multiple truss objects along the full length of the guideline
Horizontal Placement
Places horizontal trusses; the hanging angle is 0 (zero) degrees
Vertical Placement
Places vertical trusses; the hanging angle is 90 degrees
Custom Placement
Places trusses at the specified Hanging Angle
Maintain class of symbol
Uses the class specification from the symbol definition; disable the mode to insert the truss into the active class instead
Hanging Angle
Specify the hanging angle for Custom Placement
A truss object whose symbol definition cannot be located will display with default geometry, until a replacement symbol is assigned.
Concept: Rigging objects
Placing a new truss line
Adding trusses to an existing system
Adding hinges to an existing system
Placing a new hinge
Truss properties
