Detail drawings
The tools from the Detailing tool set refine the detail drawing with either 2D or 3D detail objects. These tools can significantly reduce the amount of time necessary to make an accurate representation of an object. Detailing tool objects can be used in conjunction with other objects, such as groups, symbols, rectangles, and polylines. The following illustration shows several examples of each, used in conjunction to create a fully-developed detail form.
Creating holes
Keyways
Screw threads
Inserting fastener objects using the Fastener tool
Bolts
Nuts
Screws
Pins
Retaining rings and washers
Rivets
Gears
Pulleys
Sprockets
Roller chains
Shafts
Keys
Bearings
Belleville springs
Structural shapes and details
