Nuts
Acorn nuts
Mode
Tool
Tool set
Acorn Nut
Fasteners
Multiple acorn nut and hex cap nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert an acorn nut:
Click the tool and mode.
Parameter
Description
Size
Select the acorn nut size
Style
Specify the acorn nut style
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the acorn nut with center line(s)
Show Hole
(3D only)
Draws the acorn nut with a center hole
Inserting fastener objects using the Fastener tool
Hex cap nuts
Knurled thumb nuts
Wing nuts
