Hex cap nuts
Mode
Tool
Tool set
Hex Cap Nut
Fasteners
Multiple acorn nut and hex cap nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a hex cap nut:
Click the tool and mode.
Parameter
Description
Size
Select the hex cap nut size
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the hex cap nut with center line(s)
Show Center Hole
(3D only)
Draws the hex cap nut with a center hole
Inserting fastener objects using the Fastener tool
Acorn nuts
Knurled thumb nuts
Wing nuts
