Thumb screws
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Thumb Screw
Fasteners |
The Thumb Screw tool and Thumb Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a thumb screw:
Click the tool and mode.
Parameter |
Description |
Screw Type |
Specify the thumb screw type
Point Type |
Select the thumb screw point type
Size |
Select the thumb screw size |
Length |
For a custom length value, deselect Use Standard Length Increments and enter the length under the screw head |
Thread Style (2D only) |
Select the thread style; see Fastener object thread styles |
View (2D only) |
Select the 2D view
Use Standard Length Increments |
Automatically adjusts the length to the nearest increment based on size, per ASME standards; deselect to enter a custom length |
Show Center Line (2D only) |
Draws the thumb screw with center line(s) |
Show Threads (3D only) |
Draws the 3D thumb screw with threads
