Linear roller chains
Mode
Tool
Workspace: Tool set
Modes for Creating single lines
Roller Chain - Linear
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple roller chain tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The 2D linear roller chain is a linear object, while the 3D linear roller chain is a point object.
To insert a linear roller chain:
Click the tool and mode.
Parameter
Description
Std. Chain No. (Pitch)
Select the standard ANSI or ISO roller chain number; the pitch is given as a reference
Length
(2D only)
Specify the length of the 2D roller chain by entering a value here or by clicking and dragging one of the chain control points; as the length increases, the number of links increases (depending on the selected pitch)
No. of Links
Enter the number of links; the length automatically adjusts
Start with Pin Link
Begins the chain section with a pin link; otherwise, the section begins with a roller link
Show Pins
(3D only)
Displays the pins
Circular roller chains
Offset links
