Creating doors
Tool |
Tool set |
Shortcut |
Door
Building Shell |
Alt+Shift+D (Windows) Option+Shift+D (Mac) |
The Door tool creates doors based on a door style resource and/or the parameters specified in the Door Preferences dialog box. Doors can be created in Top/Plan view or a 3D view. There are two methods for creating a door:
Click to insert a door based on a style or the parameters in the Door Preferences dialog box; see Inserting doors.
Draw the door manually using a style or the parameters in the Door Preferences dialog box; see Drawing doors.
Mode |
Description |
Standard Insertion |
Inserts a door with the parameters specified in Door Preferences |
Offset Insertion |
Inserts a door according to an offset reference point |
Interactive Sizing Insertion |
Draws a door manually, with the size and location indicated |
Wall Insertion |
Toggles between enabling and disabling door object insertion into a wall; see Wall Insertion mode |
Alignment modes |
For Standard Insertion mode and Offset Insertion mode, these modes change the alignment of the insertion point along the X axis of the door; see The Symbol Insertion tool |
Corner to Corner |
For Interactive Sizing Insertion mode, defines the door by clicking two diagonal points |
Center to Corner |
For Interactive Sizing Insertion mode, defines the door by the distance from the center to one corner |
Door Style |
Opens the Resource Selector to select a door style for placement; double-click a resource to activate it |
Preferences |
Opens the Door Preferences dialog box, to set default door parameters; see Door settings |
