Door properties
To edit door parameters in the Door Settings dialog box, click Settings from the Object Info palette, double-click the door to open the Door Settings dialog box, or right-click on a door and select Edit from the context menu.
When multiple door objects are selected for editing, and if the parameter settings of the selected objects are different, parameters display in an “indeterminate state.” Any values changed through the dialog box are changed for all the selected objects.
Door objects can also be edited from the Object Info palette. If the door has been inserted as a plug-in object, most settings from the Door Settings dialog box display. If the door is a black symbol made from a door object, fields pertaining to door geometry do not display. See Concept: Vectorworks symbols.
For doors using object styles, the parameters that are set by style display for informational purposes but cannot be edited from the Door Settings dialog box or the Object Info palette.
Most, but not all, parameters can be edited from both the Door Settings dialog box and the Object Info palette. The fields in the Object Info palette are named similarly (but not always identically) to those in the Door Settings dialog box, and roughly reflect the order in which settings are entered in the dialog box, for ease of editing. Curtain wall doors have limited parameter options.
The door parameters are described in Door settings. Only the parameters that are different are described here.
Parameter |
Description |
Insert |
For doors in a wall, specify where to insert the object relative to the wall, its core component, or its designated insert location |
Offset |
Enter the offset of the insert perpendicular to the wall's path |
Flip |
Click to flip the orientation of doors inserted in a wall; relevant parameters set by instance are changed to match the door's new orientation. See Interactive handing of doors for a visual way to change door orientation and related parameters. |
Set Position |
For doors inserted in a wall, click to activate the Move by Points tool in Reference Point mode and move the door by a specified distance from a reference point |
Wall Closure |
For doors in a wall, opens the Wall Closure dialog box; see Wall closure settings. See Additional plug-in object style and instance options for information on wall insertion options in the Plug-in Object Style Options dialog box or Plug-in Object Options dialog boxes. |
Style |
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Changing plug-in object styles from the Object Info palette. Editing a style changes all instances in the file that use the style. |
Select From Catalog |
For a plug-in object style with the catalog item set by instance, click to select a catalog item; see Selecting catalog items for plug-in object styles |
Hide style parameters |
Hides the parameters that are set by style and by catalog; these cannot be edited from the dialog box or Object Info palette |
