Design SuiteEditing custom cabinets
To edit custom cabinet parameters, click Settings from the Object Info palette, double-click the custom cabinet to open the Custom Cabinet Settings dialog box, or right-click on a custom cabinet and select Edit from the context menu.
When multiple custom cabinet objects are selected for editing, and if the parameter settings of the selected objects are different, parameters display in an “indeterminate state.” Any values changed through the dialog box are changed for all the selected objects.
The custom cabinet parameters are described in Creating custom cabinets. Only the parameters that are different are described here.
A custom cabinet’s dimensions can also be edited using the Reshape tool; see Reshaping objects.
Parameter
Description
Flip
If the object is in a wall, click to flip the object orientation
Set Position
If the object is in a wall, click to activate the Move by Points tool in Reference Point mode and move the object by a specified distance from a reference point
Save Custom Cabinet
Saves the selected object as a resource in the active file; enter a name
Replace Custom Cabinet
Opens the Resource Selector; double-click an existing resource to replace the selected object
