Design SuiteAdding text to a database
Command
Path
Add Text to Database
Text
Text objects can be added from the drawing to a selected database. This is convenient for retrieving text from older, converted files for use with the Notes Manager or when adding frequently-used text to a database for easy future insertion as an annotation.
To add drawing text to a database:
Select the command.
The Add Text to Database dialog box opens. Specify which text objects to select and indicate in which databases to search for duplicated text.
Parameter
Description
Add Text Meeting These Criteria
Specifies the criteria for selecting text objects to be added to a database
Selected Text Only
Adds only selected text to the database; when deselected, adds text from all text objects in the file
Layers/Classes
Adds only text from the specified layers and/or classes to the database; when deselected, adds text from text objects in all layers or classes in the file
Exclude Text Already in One of These Databases
Lists the databases in which to search for duplicated text; the text search is case sensitive and the match must be exact. If duplicated text is found, it is not added to the database.
Add
Adds a database to the text search database list
Change
Allows changes to a selected database’s location
Remove
Removes a database from the text search database list
Click OK. If any of the text is not found in the text search database(s), the Notes Manager: Add Text to Database dialog box opens.
The left side of the dialog box is the same as the general Notes Manager; see Managing database notes. The right side of the dialog box displays the list of text available to add.
From the Text to Add list, select a note. The current text of the note in the drawing displays in the Note Text field on the right side of the dialog box.
Do one of the following:
Select a current database entry and click < Update to replace the database text with the note text from the drawing.
Select a database section and click < Add to add the drawing note text as a new database entry in the section.
Reconciling database and drawing notes
Notes management with databases
Concept: Notes management
